Home > Technical > Hazard lights, alarm and central locking faults.
RichW
Have a 2007 RRS. Today whilst driving the central locking sysytem kept trying to lock/unlock the car. This continued once parked and the car kept clicking with the hazards lights. After about 20 minutes the alarm started up too. At which point the Sat Nav and heating lights kept turning on and off and eventually a park brake fault. The AA chap tracked down moisture in the fuse box under the bonnet. Has anyone had this before / know the cause / or the Fix please. The car is now locked manually and disconnected from the battery. Thanks in advance.
Post #570316 Sun Dec 02 2018 7:14pm
jim4244
England 2013 Range Rover Sport SDV6 HSE Santorini Black
I would be tempted to start by simply drying the fuse box out using a hairdryer or similar. Then inspecting the casing for cracks or splits.
If you don’t find any then give a good squirt of electrical moisture removal spray and see if that helps?
Jim
Post #570317 Sun Dec 02 2018 7:19pm
RichW
Thanks Jim, I was thinking about trying a hairdryer. Concerned water, albeit minimal has got in there. And the battery area too.
Post #570318 Sun Dec 02 2018 7:35pm
jim4244
Is it on your driveway or can you get it undercover?
Has the weather where you are been particularly wet?
Jim
Post #570320 Sun Dec 02 2018 8:21pm
RichW
On a driveway, it’s been quite wet recently. The car is parked on a slope, wonder if the seal under the bonnet has failed and leaked into the engine bay? Had it 10 years parked in the same place and never had an issue. Can’t get it under cover I am afraid.
Post #570322 Sun Dec 02 2018 8:28pm
Bodsy
Site Sponsor
Common is the transfer case control module behind the battery. Take the connectors off and check for green/blue corrosion.
Could also be anything on the canbus, so rear wiring connector that’s behind the rear passenger side wheel arch. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #570397 Mon Dec 03 2018 10:08pm
