Home > General (L494) > Fuming! Advice needed!! |
J2D Member Since: 28 Feb 2014 Location: Essex Posts: 341 |
Just continuing to read through the handbook and it also states - The engine oil has to be hot, and the engine has to have been switched off for 10 minutes. At present the oil will be cold, car was last used at about 5ish.
Thu Nov 29 2018 9:04pm |
Should a warning have come up on the dash to warn me if it was overfilled? |
Thu Nov 29 2018 9:11pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
I'm guessing that you have the V6 diesel. Do a search for DPF and oil dilution. It could mean that there is diesel in your oil from re-generation cycles. As your distance to service is reducing disproportionately to the distance you have driven, it may be getting worse. |
Thu Nov 29 2018 9:30pm |
Yes sorry it’s the SDV6 diesel |
Thu Nov 29 2018 9:32pm |
Violetpiano Member Since: 03 Jun 2014 Location: London Posts: 561 |
You can check the oil level without running your car and then having to wait 10 minutes or so.
Thu Nov 29 2018 9:37pm |
Just been out for a quick drive to get the oil hot, left it 10 mins after getting home, and the oil level is ‘OK’ It’s on the max, but ok, which is a massive relief, but still have the problem of the distance until the next oil service dropping 1650 miles in 185 miles traveled!
Thu Nov 29 2018 9:48pm |
BoldlyGo Member Since: 13 Jan 2006 Location: Surrey Posts: 216 |
I had exactly the same
Thu Nov 29 2018 10:00pm |
Thanks for the info and advice. I did read up on most of the posts on here, re oil dilution and crankshaft issues, and because of that, got the dealer to confirm in writing, that any future crankshaft issue would be covered under the extended warranty. But I’m still worried I’m going to have future problems
Thu Nov 29 2018 10:10pm |
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 |
Worrying bloody days with this oil dilution and crankshaft milarky eh?
Thu Nov 29 2018 11:12pm |
Yep! Half tempted to throw it back at them tbh, and buy a MY17 diesel model, or do they suffer from the same problem too? |
Thu Nov 29 2018 11:18pm |
GJW1 Member Since: 19 May 2015 Location: UK Posts: 447 |
If you bought used from main dealer they have two years warranty i thought. |
Thu Nov 29 2018 11:33pm |
They do, and I still have 6 months left on the 3 year manufacturers warranty, but I fear it’s a case of when not if, the engine is going to break! And even if it is covered, do I want a RRS that has had a new engine fitted? |
Thu Nov 29 2018 11:43pm |
Just raise your concerns with the dealer and ask them to check it over. It wouldn’t worry me owning a 2016 car with 23k on the clock give it another 3 or 4 years and 70k and out of warranty I would worry about repair costs.
Thu Nov 29 2018 11:58pm |
re GJW1's comment, he is very right to point out the fear of owning RRS L494 diesel which is outside warranty with 50k+ miles on clock.
Fri Nov 30 2018 9:33am |
