Home > General > Puddle Lights in Mirrors |
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 |
I was wondering if any of the 2010-2013 models had puddle lights fitted in the mirrors and if so does anyone know the part nos? 2016 Black SDV8 Autobiography
Thu Nov 15 2018 7:38pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5001 |
CTZ500010 you will also need to activate them in the CCF files, not sure if all mirrors had the wiring though, if mirror has the blanking plug in the bottom would imagine it has, if not If I remember correctly it's a purple wire pin no.11 in the multiplug and pin 12 on the door module. under the door panel.
Thu Nov 15 2018 8:36pm |
Thanks for that, i'll have a look 2016 Black SDV8 Autobiography
Thu Nov 15 2018 8:59pm |
I didn't have the cut outs in my mirrors so after a bit of searching I found that the Drivers Mirror is LR042654 and the Passenger is LR042658 (this is for cars with memory, powerfold, and puddle lights).
Tue Nov 27 2018 10:58pm |
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 |
not badly priced on ebay either . Good job, can you get the logo'd lamps ? so it can project something on the floor |
Wed Nov 28 2018 8:27am |
The logo lights are the next stage to look at 2016 Black SDV8 Autobiography
Wed Nov 28 2018 8:36am |
Just a question , did the door mirrors you purchased come with everything except the glass and front cap ? |
Wed Nov 28 2018 9:00am |
The mirrors needed the glass, motor for glass, cover and the puddle lamps. 2016 Black SDV8 Autobiography
Wed Nov 28 2018 9:11am |
If you fit RRS2 mirrors you can have these puddle lights.
Wed Nov 28 2018 9:53am |
Can you fit RRS2 mirrors to a 2012 L320 , i assume a RRS2 is a later variant ? |
Wed Nov 28 2018 11:10am |
No, the lens unit unclips from underneath the mirror and you get to the bulb from there. 2016 Black SDV8 Autobiography
Wed Nov 28 2018 5:14pm |
Yes. Cheers Col |
Wed Nov 28 2018 7:31pm |
I like that, have you connected the indicators? 2016 Black SDV8 Autobiography
Wed Nov 28 2018 7:40pm |
Yes, just connected the wire to the side repeater feed and blanked off the repeater lamp hole.
Wed Nov 28 2018 7:46pm |
