![]() | Home > Technical > 30mm Lean on Drivers Side |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5037 ![]() ![]() ![]() |
Get it calibrated.
accyis Member Since: 06 Feb 2010 Location: Lancashire Posts: 109 ![]() ![]() ![]() |
Hi. Thanks for your quick reply. Sorry, i forgot to mention that an independent Land Rover Service Centre recently calibrated it whilst it was in for something else however this didn't appear to make any difference. |
Try somewhere else ? |
Hi. I may well have too as it's really annoying. However I really distrust my local Land Rover Main Dealership where I purchased the last one i had. During the 2yr warranty on my last Sport I think I saw them more than my wife. I swore I'd never return to hear their guff again. So not too sure where to go to be honest.... |
You could buy an gap iid bt ยฃ425 and do it yourself.
IOMMAN Member Since: 26 Aug 2018 Location: Peel Posts: 13 ![]() ![]() ![]() |
Mine had a lean to the drivers side by about 30mm, I tried calibrating it with my IID tool but it was not successful. Took it to our LR dealer 2 weeks ago and had it calibrated and itโs been level since - it cost me an hours labour |
Thanks IOMMAN. I may have to grin and bare it at my local dealers. |
This was a photo of my 4x4 info screen which only showed one corner low, but the dealer said that they plugged it into their diagnostics and all the suspension was actually out of calibration. It now drives and rides a lot better as it always felt heavy the the OSR
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 ![]() ![]() |
If you get the car plugged in to a GAPII tool or similar, it will show the height sensor readings of each corner, and if there are any faults.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
Could just buy the GAP Eas Diag. tool, half the price of the GAPIID tool but obviously is only for the EAS, but if I remember correctly will read other codes but can't clear them or change CCF files.
from that picture, the car knows it's leaning.
Hi Andy K. I have raised and lowered to normal height as suggested (with brake off) and it's still the same unfortunately. It's a frustrating little fault!
My car has gone 4 weeks since it was recalibrated by our LR dealer and it sits perfectly level - my wife dropped me off yesterday and I watched her drive away and itโs was spot on, plus all the bars are now level on the info screen
