Home > General > New model?
Cymruambyth
Wales
New model?
Spotted...
 Steve.
Post #569433 Thu Nov 22 2018 11:33am
Tyrefitter
Well if its the new model it needs a MOT as it ran out in January this year Shocked
it was tested on the 10th of jan but failed on a few things
Reason(s) for failure
•Nearside Front Body has a projection caused by damage arch (6.1.C.1)
•Offside Front Body has a projection caused by damage arch (6.1.C.1)
•Exhaust has a major leak of exhaust gases (7.1.2)
•Emissions not tested (7.3.A.1)
•Offside Front Headlamp aim not tested (1.8.A.1c)
•Offside Front Headlamp not working on dipped beam (1.7.5a)
•Rear Registration plate lamp not working (1.1.C.1d)
•Windscreen wiper does not clear the windscreen effectively x2 n.s.f & o.s.f. (8.2.2)
•Front Windscreen washer provides insufficient washer liquid (8.2.3)
•Offside Front Lower Front suspension has excessive play in a lower suspension ball joint (2.5.B.1a)
•Offside Rear Sub-frame attachment rubber mounting deteriorated resulting in excessive movement (2.4.G.2)
•Nearside Rear Sub-frame attachment rubber mounting deteriorated resulting in excessive movement (2.4.G.2)
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #569440 Thu Nov 22 2018 12:44pm
Brit Plumber
Is that not the stormer concept model? Even with those MOT fails it’s a valuable Ka! 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #569442 Thu Nov 22 2018 12:49pm
Cymruambyth
Wales
Andy.
Why did you check the MOT? Laughing Could be an old pic anyway Very Happy Steve.
Post #569443 Thu Nov 22 2018 12:55pm
