![]() | Home > General (L494) > Considering a steering wheel disc lock |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 919 ![]() ![]() |
The disc lock is very visible. They don't want to be making any noises so will move on to someone else. I would go for it |
Pity that the RRS has so many controls and an airbag on the steering wheel as last summer I bought a removable steering wheel and a steering column lock for my Defender. The steering column lock covers the boss and is free-wheeling so they cannot use a pipe wrench to turn the steering, it also cannot be jemmied off.
DangerMouseUK Member Since: 16 Jul 2016 Location: London Posts: 528 ![]() ![]() ![]() |
I have a feeling whatever was causing them to be stolen was quietly changed in MY18 onwards with the new keys.
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
The only wheel lock worth buying is Disklok...Thatcham approved. I have one on mine ![]() |
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412 ![]() ![]() |
My experience with a disk lock, albeit a long time ago is that they are a pain to store in the car when you are travelling with passengers unless you want to get out and put it in the boot every time,. The newer ones are even longer / more bulky. RRS MY17 SDV6 AB
Better than getting car nicked. Steve. |
Violetpiano Member Since: 03 Jun 2014 Location: London Posts: 561 ![]() ![]() |
I used a disklock on my previous and current RRS. Yes it is a bit fiddly to remove and you need to be careful that it doesn't flip open while taking in / out of the car as it could easily cause a dent or chip some paint away.
J2D Member Since: 28 Feb 2014 Location: Essex Posts: 341 ![]() ![]() |
Yes this is the one I’m going for, although I was going to get the small, as it states it for sizes 35-38.9cm, and the medium is for 39-41.5cm. I measured our wheel at 38cm |
Dobby Member Since: 02 Jan 2018 Location: East Seaxe Posts: 102 ![]() ![]() |
It’s basically this Back in 2015 there was a recall on all 2013 onwards vehicles across the range I think. There was apparently a hardware problem with the keyless system that allowed the key signal to be copied to a blank key without needing access to the key or car. The fix, as eluded to above resolves the problem and also stops additional keys being programmed to the vehicle. This was different to the current keyless repeater attack, that seems to be de’rigueur at the moment. There is also the old problem of an OBD key coder being plugged in by someone with nefarious intent. MY15.5 HSE MY13 110 MY87 90 (ex-mod) (for sale) |
Ah right...mine is 40 cms I think ![]() |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 473 ![]() ![]() |
I found this and then got up and measured mine..
kmpowell Member Since: 23 Oct 2016 Location: UK Posts: 259 ![]() |
I use a ‘small’ on mine. Perfect fit.
Thanks mate,
Yes it’s the official disklok ‘bra’. I’ve been using it for 5years on all the cars I’ve owned and I’ve never had any issues with the leather being marked and/or indented. The leather wheel on my previous RS4 was very soft and the ‘bra’ protected that for two years, no issues.
