Home > Faults & Fixes > Low battery / start car
Pakolainen
Finland 2013 Range Rover Sport 3.0 TDV6 Autobiography Rimini Red
Have had this warning flash up several times over the past week or so. Most noticeably when coming back from a 1 hour 45 drive where my speed was a constant 115km/h.
Have a front and rear dash cam installed since the spring and haven't had the warning come on. Not even when the car was parked up for a week a the airport whilst on holiday. SWMBO has come up with all manner of reasons, such as switching the engine off after taking foot off brake, or opening a door before engine is switched off.
Any advice - time for a new battery? This would be the 3rd time in 3 years that i change a battery in 3 years (albeit in different cars)
cheers 2019 RRS P400e Autobiography
2014 RRS 3.0 TDV6 HSE Dynamic
2006 RRS 2.7 TDV6 HSe
Alfa Romeo Guillietta 2.0 JTDM 2011
Mazda 3 1.6 2010
Subaru Impreza 2.0 WRX 2005
Post #569228 Mon Nov 19 2018 1:19pm
Tyrefitter
Mine does the same even after a 2-3 hour drive,,im sure mine is the stop start battery as I never have any probs starting the car & its since I fitted the dash cam.
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #569234 Mon Nov 19 2018 1:48pm
Lindab
I had the same, its the Stop/start battery which is located behind the right hand panel in the boot. Needs a hard pull to open it Have cut & paste my earlier post on it
Just fitted the Auxiliary battery to my Range Rover Sport. Euro car parts did not have one in stock & wanted £125.99.
Purchased the proper Exide EK151 AGM 12V 15ah 200 amp from ebay seller (starterbatteries2011) for £48.90 delivered.
I emailed them asking if it was the correct battery for my car & they replied almost immediately. Ordered it around 4pm Friday & was told it would be delivered on Tuesday which was ok but it arrived next day. Wow that is some service. Also the battery it replaced was 14AH 200amp & this one is 15AH 200amp. So if you need one this is the go to place as far as I am concerned.
Took me about fifteen minutes & most of that was taken up pulling the panel open.
Post #569236 Mon Nov 19 2018 1:56pm
BigBen
Had this problem when a Blackvue front and rear dash cam set was professionally installed. Had it removed and replaced by the same installers with a Thinkware set. Problem solved. Blackvue was causing very excessive battery drain for some unknown reason and had same issue with two Blackvue replacements for the original one.
Post #569243 Mon Nov 19 2018 4:29pm
Tyrefitter
I have the thinkware & mine is always showing low battery Sad
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #569246 Mon Nov 19 2018 5:39pm
Pakolainen
I have the Blackvue and haven't had any issues until now. Was also surprised that after 1 hour 45 minutes driving that the battery would then flash up as being low. Figured it would recharge during that time.
Thanks. Will unplug the camera from the fuses in the boot and see if that changes the situation. Although Murphy's law would entail that is when something will happen and a camera would have been useful. 2019 RRS P400e Autobiography
Mazda 3 1.6 2010
Post #569251 Mon Nov 19 2018 7:16pm
