Home > Technical > Map Update - how long does it take?
rickshaw
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
I am in the process of downloading the latest map update onto a USB stick (which seems to be taking a VERY long time!).
The installation instructions suggest that the engine should be running to update the map on the car.
Any idea how long the update takes (once the USB stick is plugged into the car)?
If it takes as long as the download to the USB stick I may need to ensure I have a full tank of diesel!!!!
Post #569080 Fri Nov 16 2018 4:09pm
jimbg
I presume you are downloading from the HERE website for the current mapping system?
If so, then it around 22GB and depends on your connection speed, probably several hours!!
To load into the car is much faster, usually around 30 minutes. 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #569081 Fri Nov 16 2018 4:55pm
rickshaw
Hi jimbg
That's a relief!
Yes I'm downloading from the In Control 'Maps & Services' web site.
Download now at 56% with just under two hours remaining...….
Thanks for your response
Post #569082 Fri Nov 16 2018 5:04pm
jimbg
I presume it downloads the full data set, because there is no way of knowing how old your installed maps are.
When it loads onto the car it must just copy the changes that it finds. 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #569087 Fri Nov 16 2018 5:56pm
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
30 minutes? I just put the 2018 update in from USB and it took approx 2 1/2 hours, done in one go. It did start slow, almost at standstill in bits then was much faster towards the end. 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #569098 Fri Nov 16 2018 8:40pm
TubaPlayer
What link did you use to get the update from?
When I looked it said I had to put a USB in to get some data so that it knows what to update but I can't seem to find the option on the screen.
And one last question, which USB port do you plug the stick into? 2016 Black SDV8 Autobiography
2013 Grey Black Edition SDV6 (lasted a while but gone now)
2005 Grey Supercharged Sport (gone but never forgotten)
Post #569099 Fri Nov 16 2018 8:55pm
Extract from HERE website for genuine USB sticks, wouldn't know on pirate copy.
https://landrover.navigation.com/cms/page....erEMEA/GBP
How long will it take to download the map data?
The complete download process may take up to 2.5 hours dependent on the amount of information in the map region download. An example of current USB download times is shown in the following list:
• Europe - 2 hours 25 minutes
• NAS - 2 hours 03 minutes
• Russia - 29 minutes"
What happens if I switch the ignition off during the download?
PLEASE REFER TO THE DETAILED MAP UPDATE INSTRUCTION GUIDE INCLUDED IN THE USB PACKAGE RECEIVED.
During the Map upload process IF the ignition is switched off and the vehicle is shutdown, providing the USB stick IS NOT removed the upload will continue when the car is started again.
If the USB memory stick is removed from the USB port during the Map Upload process; the ignition must be switched off, the vehicle locked, then unlocked. The ignition should be switched back on and the USB memory stick re-inserted to enable the Map upload to be completed.
Post #569100 Fri Nov 16 2018 9:13pm
jimbg
Yes, for the CURRENT mapping system, you have an older car with a different system. 2023 P440e SE Dynamic on order -cancelled
2006 HSE
Post #569113 Fri Nov 16 2018 10:58pm
Moved
Post #569116 Sat Nov 17 2018 12:25am
insiorc
Ah, apologies....I guess a signature would come in handy as I did check the model profile which was 2013 RRS. I don't remember what year/model each member has. 13MY Range Rover Sport Autobiography SDV6 - mine
Post #569119 Sat Nov 17 2018 7:59am
rickshaw
Thanks for all comments to my original post.
Just for info I have now successfully installed the latest update on my 2019MY Sport.
The download to the USB Stick seemed to take 'forever' buy maybe that was delayed by my PC dropping into sleep mode at times during the download??
Anyway the installation process was completed in approx 15 minutes.
Post #569274 Tue Nov 20 2018 9:30am
