Home > Faults & Fixes > Epb dashboard light??? |
Ziceman Member Since: 08 Nov 2018 Location: Northern Ireland Posts: 18 |
Please is there a answer to my questions. |
Wed Nov 14 2018 9:02pm |
I’ll take a look at the wiring diagram tonight. 2019 5.0 SC SVA (Current)
Thu Nov 15 2018 8:11am |
Thanks @Brit Plumber for reply that would be appreciated,
Thu Nov 15 2018 2:34pm |
I’ve looked at the wiring diagram and the control of the lamp is from the Parking Brake Module underneath the car. You could do a continuity check between pin F4 on the module connector to pin 20 on the instrument cluster connector as it may be a wiring issue. If you find a fault in the wiring there is another body to chassis connector which you can check for corrosion. If the wiring has continuity then I think it’s the parking brake module or at least the connector (could be worth giving this connector a real good clean).
Thu Nov 15 2018 10:15pm |
All that went over my head😎, will pass on diagram to someone that understands, hope it's corrosion, I've looked at stripping dashboard and looks like there LEDs soldered and pulling out the clock handles which looks it needs delicate touch which I certainly don't have. |
Thu Nov 15 2018 11:04pm |
Update I put it through MOT and passed, NI Mot is much more stringent then the mainland imo. I waffled to him to distract him while doing the brake test lol, when he put it on the ramp and doing his inspection's he dropped down ramp and leaned in vehicle never seen this before in all tests I've put cars through, he obviously could not tell handbrake on or off so he jumped in and then ramped up and more tests, off ramp he was playing around as I could see him stop start and looking at dashboard, got out thumbs up...phewwww. another year.
Sun Dec 16 2018 1:25pm |
