Home > Off Roading & Green Laning > Recovery Points?
HughN
Wales
Recovery Points?
I know the standard recovery points are "for on-road use only" but is there a case for exposing them before going off-road?
Post #568931 Wed Nov 14 2018 10:26am
Tim in Scotland
Oh yes.......... saves wellies full of water and wet sleeves trying to remove the covers and attaching the recovery eye if you do need assistance! Even if they are the screw in eye type recovery points which aren’t that great but will get you out. If you have a pre 2010MY / Facelift RRS then you have permanent recovery points well up to pulling the car out that are fixed to the chassis. With my last RRS L494 I only had one recovery eye which seemed a bit pointless so I purchased a second one to have one in place at each end should the worst happen, never needed them in the end. I would be interested to know what the D5 has as RRS and FFRR both have screw in eyes now. If you have a fixed towbar at the back then that can be used too. Removable towbars can do the job but I was always a bit worried it might come adrift at a crucial moment! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #568932 Wed Nov 14 2018 10:33am
Yes, I removed the front cover as soon as I bought the car, and the rear has a two attachment with recovery point. Thumbs Up --
Post #568933 Wed Nov 14 2018 10:33am
HughN
Wales
Thanks. Thumbs Up
On a mission to avoid getting muddy, I've just been out to see what's behind the panels - and knelt in fox Censored
Mud would have been preferable!
Post #568934 Wed Nov 14 2018 10:58am
Buckster
Standard recovery points are plenty strong enough, see link below Thumbs Up
 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #568940 Wed Nov 14 2018 12:17pm
No recovery points used I that video, Chris. They bolted straight to the chassis. Whistle Thumbs Up
However, the recovery points front and rear are fine for recovery of a stuck RRS (or someone else if you're being helpful). Obviously, if the thing is axle deep in sticky mud then care is required as the loads will get high very quickly, but otherwise no worries using the front or rear loops. Both are attached to the chassis cross members (a tube at the front, a bigger piece at the rear. The rear point is part of the casting that includes the tow bar receiver. Both points can be used dynamically but dynamic recovery needs to be done properly or it can get nasty very quickly. Don't try dynamic recovery with a standard rope, of course!
As always, use a decent rope with decent attachments at each end. A soft shackle is a useful thing and safer than a big metal one when it fails! (I don't currently have soft shackles but do keep thinking they would be a good thing to have). 2012 SDV6 - it's missing a couple of cylinders
Post #568959 Wed Nov 14 2018 5:08pm
Buckster
Ner Ner spoil sport! They are very strong though Laughing 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #568961 Wed Nov 14 2018 5:20pm
Rolling with laughter Rolling with laughter Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #568966 Wed Nov 14 2018 5:57pm
syl
My MY17 has a fixed eye at the front. The screw-in eye is for the rear (or you could use the towbar). RRS MY17 SDV6 AB
Evoque MY17 TD4 AB
Post #568985 Wed Nov 14 2018 9:31pm
