Home > Technical > Valet Pin on - Just purchased car.
rr08ce
United Kingdom 2008 Range Rover Sport 3.0 TDV6 HSE Firenze Red
Hi
I've just bought a 2009 Irish RRS in the UK.
Applied for logbook pack from DVLA so just waiting on that.
When I go start the car, it says Valet mode on - Enter PIN.
I can't access the tailgate, satnav, audio etc due to this.
Spoke to Land Rover near mine who advised they can't help and wanted to charge £150 to diagnose.
Is there any way I could get the pin or are there modules and the screen I could just replace to get it working?
Like could I just fit a newer android play head unit to cure this?
Post #568594 Fri Nov 09 2018 9:53am
Tim in Scotland
Have you contacted the previous owner/ seller? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #568595 Fri Nov 09 2018 10:00am
Brit Plumber
I wonder if the IID tool could fix this, could be worth buying one anyway or borrowing one and paying for an additional key. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #568596 Fri Nov 09 2018 10:21am
There is a master pin code 1926 not sure it applies to your car though.
Post #568597 Fri Nov 09 2018 10:38am
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
How about 2121 RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #568598 Fri Nov 09 2018 10:40am
rr08ce
Hi all,
Contacted previous owner he said he doesn't remember and can only apologise.
Tried 1926, 2121, 2008, 1234, 0000, etc.
No Luck,
This IID Tool may be worth a look?
Could you help me look in the right direction as there may be a garage who can do this?
Post #568602 Fri Nov 09 2018 10:53am
Can be deactivated with the IID tool so would imagine any Indi with diag. equipment should be able to do it, could try 1922.
Post #568604 Fri Nov 09 2018 11:03am
rr08ce
Also
Could I bypass the locked head unit by replacing it with an android car play?
Or would this stop the tailgate from operating still?
Post #568607 Fri Nov 09 2018 11:12am
Socast
Is the code not in the manual ?
Post #568759 Mon Nov 12 2018 1:18pm
PC76
IID tool in my opinion is the way to go.
no more expensive trips to the local stealer to diagnose any issues......
Post #568788 Mon Nov 12 2018 3:52pm
