Home > In Car Electronics > 2011 RRS HSE 3.0 / TV Not working |
My car is a Sept 11 (2012 MY) and the Tv is digital. Does yours not have both digital and analogue? 2019 5.0 SC SVA (Current)
Thu Nov 08 2018 6:48pm |
iwtts22 Member Since: 03 Nov 2018 Location: Gamlingay Bedfordshire Posts: 10 |
How can I tell ?
Thu Nov 08 2018 7:48pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5002 |
Should be able to check or change it in the Audio/Video setup screen.
Thu Nov 08 2018 8:16pm |
You can use topix or if you pass your Vin someone can check it for you.
Thu Nov 08 2018 8:18pm |
Topix is not always correct though as someone on here has said i believe it say's his has a fridge but it does not |
Thu Nov 08 2018 8:22pm |
MY11 cars had Hybrid TV System as standard except the SE variant.
Thu Nov 08 2018 8:28pm |
2021 year has digital and analogue tv capability selectable within the menus and as explained in the handbook. Should be same for 2011 ? |
Fri Nov 09 2018 8:53am |
For a 2012 MY this is how I do it, 11MY should be simikar.
Fri Nov 09 2018 2:07pm |
Yep, as above |
Fri Nov 09 2018 3:31pm |
Thanks for the comments everyone
Mon Nov 12 2018 6:14pm |
See pics in post above. |
Mon Nov 12 2018 9:03pm |
My screen is totally different
Mon Nov 12 2018 9:38pm |
The MY12 on vehicles had a different screen interface view to the MY11 but would have thought you had a TV button there somewhere on the older view.
Mon Nov 12 2018 9:42pm |
Page 130 of the manual in the 2012my. Have you gone through all of the AV section of your manual ? I don't think there is much difference in AV spec 2011 to 2012 so try another look and you should hopefully see it. AV section is pages 112 to 131 tv bit 129 and 130. |
Tue Nov 13 2018 9:44am |
