![]() | Home > In Car Electronics > Sat-Nav Cant Use Postcode Search - 2012 RRS |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
its probably defaulted to belguim after the update thats why its not recognising the postcode......change the map to UK and try again.. |
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 ![]() ![]() |
Thanks for the info , How do i do this ? as couldn't see an option for it. |
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1860 ![]() ![]() |
2023 P440e SE Dynamic on order -cancelled
Omg no wonder why i didnt see it haha.
Ok tried the above on the way home.
thats a bummer...sounds like the ebay update hasnt worked then..
On my 2012my 2018 update it recommends you do it in one 3 hr session then switch off, leave at least 15 mins, then on again. Did it on a trip from west mids to Edinburgh. It can look like it is doing nothing for quite a long time especially at first but eventually it speeds up. Where did you source your key from ? |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 473 ![]() ![]() |
Most sat nav upgrades or updates must not be interrupted in any way,
Not so, recent LR Nav updates that come on a memory stick are huge and the car can be stopped and restarted numerous times during the updating, the system will pick up where it stopped until all the update is completed, just don’t remove the memory stick from the USB port otherwise the update starts from scratch. Having said that the above only works with genuine OEM updates and is not always true for copies bought from a well known auction website. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
The sad thing is i cant reapply the update |
Ok been looking at this update USB stick . I think it could be a corrupt file causing this ! So want to rerun the update i have paid for.
Can you not ask the seller about this? 2023 P440e SE Dynamic on order -cancelled
Sadly bought it from a ebay seller in June/July . I did ask him via ebay but no reply ! |
OK , managed to find a bit more info and it seems that when the update is done it actually replaces files completely on the HDD from the update source .
