Home > Technical > Power fold mirrors
Cosmo15555
United Kingdom 2010 Range Rover Sport Supercharged HSE Stornoway Grey
Power fold mirrors
One of my mirrors is playing up
It’s struggling to power fold it’s creaking and juddering
Can they be lubricated if yes what with
Thanks
Cosmo
Post #568422 Tue Nov 06 2018 6:27pm
May not be relevant after all this time, but there was a TSB/Service Action about juddering mirrors I think it involved fitting a extra washer or something like that can't really remember exactly, will see if I can find a copy, may help.
Try this one.
https://www.google.co.nz/url?sa=t&rct=...3154QtX6Fk
Post #568426 Tue Nov 06 2018 7:42pm
bazza d
power fold mirrors
i had this problem about 12 months ago on mine and and used WD 40. put the thin nozzle in the swivel area gave it a good blast and cleaned off the excess and its worked perfectly ever since. Thumbs Up
Post #568431 Tue Nov 06 2018 9:29pm
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
WD40 is not a lubricant it is a WATER DISPERSANT, hence its name WD. It will work for a while but over time it will gum up the works by attracting cr@p to stick to it. Use a spray silicon grease or at least a spray grease.
That said if they are sticking or juddering when moving then, standing alongside the door facing forward grab the mirror body and push towards the front. The mirror will move and go almost flush with the car. This distributes the lubricant and is an accepted procedure for this problem.
Hope it sorts it.
Phil
Post #568433 Tue Nov 06 2018 9:47pm
garrycol
Australia
A first world problem - back here in the backwoods I dont even have power fold mirrors Rolling Eyes 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #568439 Tue Nov 06 2018 11:58pm
mrluke
I took my mirror apart and lubricated everything with white grease . Did not really solve the problem , i think i need a new motor ... Sad
Post #568453 Wed Nov 07 2018 1:08pm
Cosmo15555
Thanks for the info I sprayed the all the moving parts on mirror with silicone spray and all working ok 👍
Post #568549 Thu Nov 08 2018 6:12pm
