![]() | Home > General > Problems Towing |
Ade99 Member Since: 28 May 2014 Location: wombourne Posts: 20 ![]() ![]() ![]() |
I am after some help/advice regarding towing.
Surprised no fault codes ? Where did you take it to find that out/what reader or tool did they use ? Could be any one of a number of things. Clearly the car ain't happy or it wouldn't keep pinging up the fault. Even if it has now gone away the warning seemed linked to the extra towing load which needs checking out. You don't want it doing this again with a load on the back. |
We have had similar issues in Aust and my 2.7 suffers the same.
Thanks for the responses
I have a BAS remap and it made no difference. 07MY RRS TDV6
Never noticed it on my TDV8 when towing but then I was always gentle with the throttle - live cargo in the form of horses tends to make one go gently.
Great thanks
Mass Air Flow (MAF) sensor or Manifold Air Pressure (MAP) sensor?? - I would have thought the MAP sensor but cleaning both may help. Care is needed with both so not to cause damage. 07MY RRS TDV6
215m3 Member Since: 13 Sep 2018 Location: Cambridge Posts: 48 ![]() ![]() ![]() |
I towed a large PRG enclosed trailer last week. Been averaging 29 mpg on the computer. Dropped to 19 mpg, but no engine fault issues.
