Home > General > Help ! Sounds like “rbot” bushes underneath my RRS2011 3
iwtts22
England 2011 Range Rover Sport 3.0 TDV6 HSE Alaska White
Hi
I’ve just invested in my first RRS
It’s been in for a health check and the dealer has informed me that the front and rear what sounds like “rbots” are leaking and need replacing along with the pipes as they are showing signs of corroding.
Can anybody give the correct name of the parts they are referring too please so I can at least have a look at what they are talking about.
Than You
Ian
Post #568213 Sun Nov 04 2018 12:12am
May mean Anti Roll Bar Bushes or the ARC Bar seals leaking, which I believe could be expensive, did you have any form of warranty with vehicle?
Post #568214 Sun Nov 04 2018 12:33am
Brit Plumber
Take everything a dealer says with a pinch of salt. They will exaggerate everything that isn’t perfect! My Indy tends to tell me if anything is ‘to be done now’ or ‘Come back in 6 months’ or ‘I’ll check it again on the next service’. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #568224 Sun Nov 04 2018 8:26am
iwtts22
Thanks gents much appreciated
Post #568236 Sun Nov 04 2018 10:51am
