![]() | Home > General > Gearbox Mega flush/torque converter/gearbox replacement! |
I know zero about automatic boxes but I would agree that it sounds stupid not to replace the filter when you’ve replaced the oil. Was this ‘mega flush’ a proper mega flush or a corner cutting drain and refill 3 or 4 times? 2019 5.0 SC SVA (Current)
German-wheels Member Since: 23 Jul 2016 Location: Bournemouth Posts: 88 ![]() ![]() ![]() |
It was a proper mega flush at a Land Rover specialist, I called and asked about the filter and they say that it gets cleaned in the process. Just seems odd to me to not replace it. |
It involves getting your hands dirty to change the filter.
The filter isn’t a “filter” as such, it’s a strainer to catch big lumps of debris.
There is a paper filter in there,
Thanks for all the replies, they say that next step is a new gearbox and TC, is there any way of identifying if both are gone or if it is just a replacent TQ? I’ve read lots of posts where a new TQ solved it, I’ve not seen many where a whole new gearbox was needed |
We dont know what the issues you are having... |
So before the flush I had juddering when I lifted off the accelerator in drive like crawling in traffic etc.
Update,
2k rpm sounds about right. I assume you mean that you stood on the brakes and revved it in drive to see what it would stop revving at? If so, mine would do around 2k rpm. 2012 SDV6 - it's missing a couple of cylinders
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174 ![]() ![]() ![]() |
Bristol Transmissions have a very good reputation on this, and I think a number of forum members have had their gearbox done there. I'm having similar issues, and spoke to the tech guy. He said that a lot of the time they just need a new torque converter, but sometimes the output shaft is worn (if IRC) as well, which means a new gearbox. They can't tell which it will be until they remove it. |
Mine was done by Bristol Transmissions. Went on for a new TC at 109k miles, ended up with them doing a recon job as the output shaft splines were worn. To change the output shaft, you have to take everything out of the casing. They then check and replace stuff as required. Of course, if the output splines are worn then the transfer box input splines will also be worn. That means a strip of the transfer box to get the input shaft out. A new transfer chain was fitted when they did that.
Thanks for the replies, what do Bristol transmissions charge for replacing a TC?
A bit of driveline shunt, I think. I guess it's one of those failures that you don't really notice right up to the point where it fails and leaves you stranded.
