Home > Maintenance & Modifications > LED HALO DRL |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4967 |
I would connect yellow to dip beam at the headlight. |
Fri Jul 08 2016 4:59pm |
tanloverluke Member Since: 19 Mar 2013 Location: Honiton Posts: 917 |
do you want the angel eyes to come on when the ignition is turned to on, or only when the headlights are on? if the former, then try to wire the yellow into the fusebox and see if this works (which it should). there are several write-ups about the best slot. Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Fri Jul 08 2016 10:24pm |
look at my post here: http://www.rrsport.co.uk/forum/post441576.html#441576 Recently bought a 2007 RRS HSE TDV6 for a Pimp-My-Ride-Project.
Fri Jul 08 2016 10:29pm |
Whether they are on is automatically detected by the voltage of the engine running.
Sat Jul 09 2016 5:20am |
Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203 |
Yes they are engine On/off recognition, I just piggy backed left headlight Dip beam fuse to try them and it works a treat, I start engine and approx 5 seconds later they illuminate, switch lights on and they don't go off they reduce brightness 50% and when I turn car off there is approx 10 second delay then they go out. So I think the set up Iv got is exactly how Andy suggests, so now it's just a case of finding the correct dip beam headlight wire to tap into under bonnet. Thanks Andy, And thanks for all replies. |
Sat Jul 09 2016 7:20am |
Dip beam is pin 11 on the headlight connector.
Sat Jul 09 2016 10:20am |
Awesome, thanks Andy. |
Sat Jul 09 2016 12:34pm |
Not the best pic but DRL,S fitted,
Thu Jul 14 2016 4:50pm |
tommymac Member Since: 18 Oct 2018 Location: lancaashire Posts: 13 |
hi gilly,
Thu Nov 01 2018 7:49am |
jason-nike Member Since: 08 Nov 2013 Location: sussex Posts: 207 |
Heres mine I fitted on my last RRS
Thu Nov 01 2018 10:32pm |
RUSK Member Since: 27 Nov 2018 Location: South West Posts: 63 |
I love the look of this - reminds me of my old BMW... are there any kits or conversions like this, suitable for someone with the technical prowess of a sausage roll to fit?
Fri Jan 04 2019 7:01pm |
I fitted mine myself.
Tue Jan 29 2019 4:37pm |
Joe Hankey Member Since: 16 Apr 2016 Location: warrington cheshire Posts: 117 |
Just looking for someone to do my car. I live in warrington. So it would be someone in the manchester/liverpool. Area but open to go somewhere else if needed. Any help would be much appreciated. |
Tue Feb 19 2019 10:32pm |
