Home > Technical > HELP !!!!!!!!!!!!!!!!!!!! |
You can either plug it into a computer and adjust it, or you can disconnect one of the oil feed pipes, move the bar then reconnect. You'll need to bleed the system afterwards (it's self bleeding, but drawing in that much air the system may struggle to purge it all under normal operation). |
Tue Oct 30 2018 11:02am |
Demaske1 Member Since: 17 Oct 2018 Location: Cheshire Posts: 26 |
thanks, we,ve managed to move it slowly. PHEW ! |
Tue Oct 30 2018 11:19am |
If anyone reads this and decides to do something similar, I suggest disconnecting both drop links and pulling the wiring connectors of the valve block on the right underside of the vehicle. 2019 5.0 SC SVA (Current)
Tue Oct 30 2018 10:34pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4394 |
Wouldn't be the first time I have seen the rams blow its seals... |
Wed Oct 31 2018 7:07am |
