Home > General > Rear Arch Liners
knwatkins
Rear Arch Liners
Hi all,
I may be going crazy, but I cannot figure out where the rubber rear arch protectors mount.
None were present on my MY2010 when I bought it so I fitted the fronts, but on the rear, the plastic wheel arch liner is below the metal of the arch - is this correct or should it be above? (And then the rubber trim fits over the metal?)
Thanks in advance!
Post #567849 Mon Oct 29 2018 6:17pm
knwatkins
Also if anyone could take a picture of theirs it would be much appreciated.
Post #567850 Mon Oct 29 2018 6:18pm
Sounds to me like liners are not fitted correctly, should be above metal wheel arch, then rubber fits over metal edge same as fronts.
Post #567851 Mon Oct 29 2018 6:47pm
knwatkins
Thanks Col. So the plastic arch liners should be above the metal, then the rubber clips onto the metal?
I did force the arch liner above the metal but I couldn't get the rubber protector on - too bloody tight.
Post #567853 Mon Oct 29 2018 6:52pm
That's how they go, not sure why pictures upside down, could be something to do with my current location in the world. Rolling with laughter
Post #567857 Mon Oct 29 2018 7:14pm
knwatkins
Brilliant, cheers mate.
Post #567859 Mon Oct 29 2018 7:33pm
Brit Plumber
There’s a problem with Cols photo. Not enough mud in that arch. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #567868 Mon Oct 29 2018 8:38pm
