Home > General > Phone connection problem
mad-dafty
Scotland 2010 Range Rover Sport 3.0 TDV6 Autobiography Stornoway Grey
Just got my 2010 Sport....I moved up from a 2006...so nice upgrade of interior...Happy as Larry. However for the life of me I cannot get my Samsung 7 to connect to the car. A have engine started, switch Bluetooth on in my phone, do a scan for devices....but Land Rover doesn't appear. All that comes up is a MAC address and a message on the phone saying "Device name will appear when this device is connected". It's an Autobiography Sport so I'm assuming it has phone connectivity. On my 2006 the same phone connected with no problem, although had to type 2121 in each time. Can someone tell me if I'm missing something obvious here....Wouldn't be the first time for me.. Mr. Green 2010 RRS TDV6 3.0 Autobiography - Stornoway Grey
2006 RRS TDV6 2.7 HSE -Java Black
2008 BMW 3 Series 2.l
2006 BMW 5 series 2.l
Post #567627 Thu Oct 25 2018 12:51pm
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
I’m not an expert but having spent a while trying to connect phones to cars Try these suggestions:
Reset your phone by switching off and on.
Try connecting another phone to see if that works
Make sure all previous phones in the memory have been deleted - the system may be full.
Do a hard reset on the car. That is disconnect the battery, connect the battery leads together using a jump cable. NOT THE BATTERY TERMINALS. Leave for 20 mins or so then reconnect.
You know about 2121.
Good luck
Post #567637 Thu Oct 25 2018 3:24pm
mad-dafty
Thanks for that, I will give the hard reset a try over the weekend...see if that helps. Thumbs Up 2010 RRS TDV6 3.0 Autobiography - Stornoway Grey
Post #567650 Thu Oct 25 2018 7:46pm
BKHK
Hi Mad Dafty
I don't have any ideas except that when I had my 2010 V8 it connected really easily to an iPhone 7. Actually, the connection in the 2010 L320 was more stable and less prone to glitches than my current L494, once you get it up and running, it should be fine. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #567664 Fri Oct 26 2018 1:24am
Eskimo
Have you tried connecting to the MAC address - the head unit I have on one of my other cars just displays the MAC and once selected it changes to Carkit in the Bluetooth list on my phone.
Might be worth a try
Post #567673 Fri Oct 26 2018 12:25pm
