![]() | Home > Technical > Suspension problem |
flybouy Member Since: 04 Feb 2010 Location: Here, there or in the air.... Posts: 44 ![]() ![]() ![]() |
Mrs. had a small crash as she drove the RRS into the side of a car.....don't ask!
jack.bauer Member Since: 30 Sep 2012 Location: london Posts: 277 ![]() |
The printout would show the mileage when the fault occurred.
Thanks, I don't have the printout but will chase it up.
eqerem Member Since: 26 May 2018 Location: Tirana Posts: 2 ![]() ![]() ![]() |
I have the same error, plx help |
Loverrs Member Since: 20 Oct 2016 Location: Manchester Posts: 19 ![]() ![]() |
I have the same problem range Rover sport 2009 2.7 V6 they told me the state angle sensor need to be changed I’ve done then they told me the compressor need to be changed I’ve done that I spent over £1600 the problem still comes up
warkman Member Since: 28 Feb 2015 Location: Warwickshire Posts: 234 ![]() ![]() ![]() |
Another with strange suspension issues.
atpsrrs Member Since: 24 Aug 2017 Location: North Wales Posts: 6 ![]() ![]() ![]() |
S4LAD have you had any luck with your sports? |
2007 RR Sport Black Member Since: 10 Jul 2019 Location: Ilford, Essex Posts: 1 ![]() ![]() ![]() |
I have a 2007 RR Sport 2.7 diesel.
inkano1 Member Since: 13 Mar 2018 Location: glasgow Posts: 5 ![]() ![]() ![]() |
Hi there wondering if anyone can give me advice on the above matter. my RRS HSE 2013 model vehicle intermittently flashes up a camber warning light if i turn a corner too fast or sometimes when i go over a bump, it tells me to stop the engine right away, once i do it and restart the warning goes away and the car is fine till the next episode, i took the car for a diagnostic and the garage said it was a fault relating to the hydraulic suspension pump and that it had been leaking, he filled up the system and it gave me no problems for around a week then started back again, do any of you know how much to supply and fit a new pump?
Disco Mikey in Dundee your best bet. Look him up on here but you will need more posts before you can pm him. |
Thanks for that I’ll post something else so I can DM him 👍 |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 ![]() ![]() |
You might want to change the compressor relay at the same time. It's not unheard of that the relay contacts stick, resulting in the pump running on permanently whenever the ignition is switched on. |
MikeG Member Since: 25 Jun 2015 Location: North Lincs Posts: 72 ![]() ![]() ![]() |
Bought ~V8 RRS from a company called Prestige Specialist cars, swindon way. I bought without seeing the car in the flesh but saw the pictures, read the write up and spoke to the owner of the garage. Seemed legit and a decent enough chap. Car gets delivered and looks ok. Next day I get underneath to have a look and its rusty as f**k. A couple weeks later I notice car leaning to offside rear. Suspension just says raising slowly but its obv not correct. I ask the dealer what to do and says make warranty claim. Warranty co won't cover air suspension on older rrs. Go back to dealer. They diagnose compressor fault and send me an unbranded compressor to change which I think, fair enough until I realise its prob a 150 quid one off bay. I fit this but makes no difference. Take car to local dealer. Up on ramps front suspension bushes shot. Rear hub rose joint thing loads of play. Faulty rear height sensor. So I ask the dealer to cover cost. Nope they won't. Say warranty co is responsible. They then 'talk warranty co' into giving me 450 toward my 1500 bill. I ask dealer to meet me half way on remaining. nope. I threaten them with small claims court, they say go ahead, so I am. I am sick and f*****g tired of these so called decent dealers fleecing folk. I am taking them to small claims court because its the principle. The air con doesn't work either. Plus the rear air shocks don't appear to have any dampening. This car passed an MOT a month or so before I bought it. no way would it have passed an MOT !!!
Risely Member Since: 02 May 2014 Location: Hertfordshire Posts: 17 ![]() ![]() ![]() |
