Home > General (L494) > Tyre Pressure monitor
jamiepgodden
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Rimini Red
Just picked the car up and noticed that the tyre valve caps weren’t fitted - seller (specialist 4x4 dealer) is going to spot them. The Tyre pressure monitor has alarmed and asked us to check the tyre pressures, one tyre is new and the others have been removed to refurbish the wheels prior collection. Is this likely as the tyre pressure valves aren’t fitted and once fitted will the system just need a reset?
Thanks in advance
Post #566960 Sun Oct 14 2018 6:22pm
Tyrefitter
What do you mean by the tyre valves aren’t fitted,the tpms should be a alloy valve,has yours just got rubber valves fitted.?.When the tpms are re-fitted they will program themselves once you set off in the car.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #566962 Sun Oct 14 2018 6:32pm
jamiepgodden
Yes they have rubber valves fitted - so I guess this is causing the computer to not detect pressure and hence the warning light.
The TPMS are being sent. So when fitted all should be ok?
Thanks
Post #566963 Sun Oct 14 2018 6:35pm
Tyrefitter
Yes once fitted the car will detect them & all will be 👍
Andy Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #566966 Sun Oct 14 2018 6:38pm
jamiepgodden
Thanks
Post #566968 Sun Oct 14 2018 6:40pm
