![]() | Home > Technical > Red triangle and restricted performance. |
Have you checked all the wiring and connectors? 2019 5.0 SC SVA (Current)
Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155 ![]() ![]() ![]() |
I have checked all the wiring that I can see which seems to be in order and all connections checked.....I have also sprayed contact cleaner on all the connectors I can see but this has not made any difference. |
I'm off to main Range rover dealer to put car on diagnostics. I did show them my diagnostics from the bt iid tool but surprise surprise THEY need to put it on theirs for about 100 euros. Seen as I can't find problem either myself or via forum members I'm forced down this cut de sac. (No indies in my area !!)
OK....I took the car into JLR and left the car with them to do the diagnostics and hopefully solve this ongoing problem.
