![]() | Home > Maintenance & Modifications > Rear brake pipe replacement. |
L/R themselves used to do repair sections for the rear pipes so you did not have to replace whole front to rear pipes, not sure if they still do them. It would involve cutting and flaring the old pipes and fitting a joiner unions at the rear of the car I imagine. Pipes were around £20.00 each if I remember right. Would probably depend on how bad and where about's yours are rusted I guess.
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 ![]() ![]() ![]() |
Thanks for the reply Col.
If it's of any use just for reference the L/R part numbers for the repair pipes were LR056967 & LR056968. Google them probably come up. |
OK I just Googled one of the part numbers you sent and the dimensions stated length 94cm.
Sorry my mistake, when you mentioned rear brake pipes I thought you meant the ones that go across the rear axle to the rear caliper flex pipes, not rear to front of vehicle.
Hi Col,
Looking at the drawing there would appear to be a joiner at the front, not sure quite where it would be probably up by the bulkhead some where. Those two pipes highlighted are about £25.00 each from L/R if you wanted genuine ones as opposed to making them up yourself, mind you if you ordered from L/R not sure what shape they would be by the time they arrived. |
Yes indeed, definitely would not be the same shape after delivery |
Just been under the car and cannot see a brake pipe connector on the original brake pipe. it looks as if it runs from the rear brake to the servo without a break in it. |
I had my rear lines replaced for £100 by my local Indy. May be worth saving your self the hassle at that price. 2019 5.0 SC SVA (Current)
Nah!!! that's the easy way out... I love to shout and swear at my car whilst getting rust in my ears and eyes |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 ![]() ![]() ![]() |
Got to be worth a trip to see Disco Mikey for this
Thanks for all your input |
