Home > General (L494) > My16 Forward Alert - emergency braking?
Netsters
I have a MY16 AB RRS.
Does anyone know the exact spec of the forward alert and assisted cruise control that comes on the car.
I use the forward alert for town traffic which is excellent, but I have never tested to see if it auto brakes in anger. I thought it did have it, but I thought i noticed for the first time on a approach to a roundabout, that the brakes applied?
Same sort of question for the ACC, anyone know the difference between what is on my car, and what they now charge you for on the MY19 models? Range Rover Sport SVR - Santorini Black
Range Rover Sport Autobiography 2016 Yulong White / black interior - Stealth pack
Ferrari 360 F1 Spider red/cream
Ferrari 348 ts red/cream
BMW M4 Convertible Competion Pack
Post #566328 Fri Oct 05 2018 1:13pm
fkarim
Can't comment on any differences between MY16 and MY19 ACC as I never looked into MY19.
I had a MY16 RRS AB and on a couple of occasions I felt the brakes automatically applied along with forward alert beeping. Can't be 100% sure whether the car took control a fraction of a second before I instinctively braked or if there was no action from the car and it was just me. I don't recall reading anything about the car having auto emergency braking. Normally forward alert only beeps. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone
Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory
Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond
Post #566330 Fri Oct 05 2018 1:32pm
scrumps
ACC and FA use the same sensor and indications but FA merely “alerts”.
MY 19 has a slight difference in that it has “queue assist” with “Stop & Go”. On 16MY, if ACC brings you to a complete stop in traffic, you have to physically have to press the accelerator to re-engage ACC. On 19 MY if the “stop” is less than 3 sec, the car automatically restarts.
I’ll find out how well it works after 1st March 19!!!
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #566340 Fri Oct 05 2018 5:23pm
Tyrefitter
I’ve got forward alert,acc & queue assist on my14 Sc & if the car in front brakes so does mine,also if the car in front stops so does mine then accelerates when vehicle in front moves away.
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #566341 Fri Oct 05 2018 6:06pm
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
ACC will follow the car in front down to a lower speed. Queue Assist will follow the car all the way to a stop. If your car stops, then it will hold and will not progress until you depress the accelerator slightly. It will then resume.
Emergency Brake Assist will stop the car as quickly as possible if you press the brake pedal hard.
Autonomous Emergency Braking (not sure available on MY16 cars) will stop the car automatically if something/someone steps out in front of you.
Post #566343 Fri Oct 05 2018 6:36pm
udash
2013 Range Rover Sport SDV6 Autobiography Firenze Red
on MY16 AB, Addition to Forward Alert, which only provides an warning there's INTELLIGENT EMERGENCY BRAKING
taken from workshop manual.
Intelligent emergency braking reduces the impact velocity if the adaptive speed control module determines that a collision is
unavoidable, even with driver intervention. It is not designed to prevent accidents from occurring. Typical activation of
intelligent emergency braking is approximately 0.8 second before impact. During this 0.8 second period the speed of the
sensing vehicle is reduced, thus reducing the impact energy.
After the intelligent emergency braking function has activated, it is then disabled, as the vehicle is assumed to be damaged.
After the vehicle has been repaired, the intelligent emergency braking function can be re-enabled using Land Rover approved
diagnostic equipment.
The intelligent emergency braking function operates at vehicle speeds down to zero, and will function even when forward alert
and adaptive cruise control are switched off.
Post #566344 Fri Oct 05 2018 7:32pm
scrumps
Phil’s,
AEB from 17MY as SWMBO’s D5 has it.
Post #566345 Fri Oct 05 2018 7:34pm
philmw
Not that intelligent then.
scrumps wrote:
AEB from 17MY as SWMBO’s has it.
Handy? Very Happy
Post #566346 Fri Oct 05 2018 7:43pm
