![]() | Home > Technical > Suspension calibration problem |
Should the rear not be 465mm, fronts 461mm?
walyhst Member Since: 06 Sep 2018 Location: CHOPPINGTON Posts: 5 ![]() ![]() |
Thanks for the reply, the iid tool says 461mm all way round, would 4mm make it not save settings? Im measuring from the centre of the hub to the wheel arch lip, Another thing not sure of but on a few posts on various forums it mentions the car needs to be in tight tolerance mode from what I understand it's done by removing the eas relay but just going off the guided calibration on the iid tool nothing is mentioned about tight tolerance mode |
No I don’t think tight tolerance mode is needed.
2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
Might well be wrong here but if you have removed a EAS relay have you not in effect disabled the eas, so how is it able to know what you are trying to do as it will not be able to do anything. I think the tight tolerance mode is used primarily for 4 wheel alignment not suspension calibration. There are a lot of member on here who have done the calibration and I'm sure one will be along shortly to tell you where you may be going wrong.
That's exactly what I thought col, maybe disabling the eas you can set the height baseline so it can't move the height itself to what ever the car thinks is level,yeh hopefully someone can help as I don't fancy RR dealer prices for labour |
I can't see anything in the Gap Users Manual about removing the eas relay during calibration, but did see this.
