Home > General > Subwoofer
Graham Ives
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Orkney Grey
Subwoofer
Hi guys not sure subwoofer working as turn bass fully down its just tinny any ideas please testing tips etc where actually is the sub located even
Regards graham Rrs sport 2012 Orkney grey
Post #566203 Tue Oct 02 2018 8:37pm
Inside rear tailgate. Have been a few posts about issues with them recently.
Post #566204 Tue Oct 02 2018 8:52pm
They aren't great! It's probably working as designed!
Thought mine wasn't working, but it was when I checked it out Rolling Eyes
Post #566206 Tue Oct 02 2018 9:06pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
It isn't the greatest, but then it isn't intended to be a pimp my ride 15 inch blow your windows out job in the first place. There are limitations based around the physical location of it in the tailgate, so the relatively small size (I think around 8 inch) and the small cavity plus absence of dampening material all conspire against it.
That said, it does work and if you are in audio settings you will hear the difference sliding the scale from fully left to right.
Many, including me, struggled with the rattly, farty distorting issue. But that is relatively easy to fix and I put a post in tricks and tips explaining this.
The audio system itself is not too bad fed with a decent source. Feed it crap quality low bit rate mp3 and don't be surprised if it sounds crap. Garbage in, garbage out. Files at CD bitrate (or tidal streaming hi fi setting) are a minimum really (16 bit 44khz). Tidal Masters or high res is better. There's a good reason why no studio or serious musician records in or listens to mp3, because it is crap frankly.
Post #566214 Wed Oct 03 2018 9:27am
Graham Ives
Thanks guys did the slider across makes no odds minus or positive Rrs sport 2012 Orkney grey
Post #566228 Wed Oct 03 2018 8:01pm
Put your ear to the tailgate trim inside.
In the right side
Post #566234 Wed Oct 03 2018 8:32pm
Father Jack
You must have a loose connection then or your system is Censored. There is no need to stick your head next to the driver if it is working, assuming you have normal hearing.
Post #566238 Wed Oct 03 2018 8:49pm
