Home > Maintenance & Modifications > brake pad warning
Wayneclarke
brake pad warning
Had the brake pad warning light come on but then go off, so had my rear pads changed as the front ones had been done last month, but then this morning on my way to work the warning has been flicking on and off ..... any ideas as to why it would be flicking on and off?
Post #566180 Tue Oct 02 2018 5:08pm
Tyrefitter
Did whoever changed them fit new sensor wires.?
Andy. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #566183 Tue Oct 02 2018 5:44pm
gogsy1956
First port of call would be the cable/ sensor that attaches to the brake pad,,, we're they replaced when the pads were done?? 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #566184 Tue Oct 02 2018 5:45pm
Oldandconfused
Or it could be the rear pads are low and the fronts are fine. They have a sensor on the front, (FNS from memory if it's the same as D3) and one on rear. They work by the disc wearing the pad down to where the sensor is, and contact with the disc breaks the circuit. Could the flickering being the intermittent contact with the disc?
Post #566192 Tue Oct 02 2018 7:37pm
Wayneclarke
Both front and back pads were changed and also new sensors so perhaps one is faulty, the warning comes up on start up flickers for a bit then disappears . Think I will run it back to the garage today , thank you for the info guys
Post #566210 Wed Oct 03 2018 6:26am
Oldandconfused
I think you're absolutely correct, they've done the work, its not right, it's down to them to sort it out. Good luck
Post #566211 Wed Oct 03 2018 7:34am
