Home > Technical > Nearside Front Door Not Unlocking (but works with keyless)
knwatkins
Hi all, I have a MY2010 RRS and I have a problem with the nearside front door not unlocking. It's very strange however because keyless entry works on this door Confused
Here is a summary of the problem:
- Keyless entry works fine
- If I press the unlock button on the remote, all doors will be unlocked except the nearside front door
- If press the lock/unlock button on the drivers door, all interior door locks will move except the nearside front door
- I can reach over and pull the interior handle to open the nearside front door from inside the vehicle
Anyone have any ideas please?
Post #566149 Mon Oct 01 2018 9:04pm
x3too
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HST Santorini Black
Hi Knw,
I have the exact same issue on my 2011 - Started during the hot spell earlier on in the year.
Reading the forums Its quite common and related to the failure of the Door locking module , As ours has keyelss I think there is another circuit to release the inside lock and somehow it opens .
You need a replacement unit , Have got one but haven't had time to swap yet. I may end up leaving till it's service in a few months time .
Lots of info on the net on how to change them .
If I get time and do it I will update .
Post #566306 Thu Oct 04 2018 10:42pm
knwatkins
Thanks x3too.
I have come to the same conclusion. I have bought one on eBay and will be fitting it this weekend. I'll let you know if it works.
Post #566310 Fri Oct 05 2018 5:02am
x3too
Thanks - Looking forward to the update - have 2 little time lately to do mine
BTW which one did you buy? Is there a difference between Keyless and non Keyless ? I bought one out of haste and hoping there is no difference - I also bought a bag of door clips from ebay as I know from past experience they break.
good luck
Post #566349 Fri Oct 05 2018 10:03pm
knwatkins
Hi x3too, so I did the job yesterday and it's now all working! Mr. Green
The actuator is a complete pig to get to and removing/refitting it involved lots of swearing!
There is a difference between keyless and non-keyless.
The part number for keyless is LR091351 = around £150 genuine LR part (no pattern part available as far as I know)
The part number for non-keyless is LR011277 = around £25 pattern part
Unfortunately, I didn't realise there was a difference and I'd already purchased the pattern part on eBay and removed the faulty one. However, with a little bit of dismantling and fine adjustments, it was possible to add the keyless part of the existing faulty actuator to the new non-keyless actuator. You have to be very careful with the springs and gears inside, paying attention to how everything fits together. It's a bit of a PITA, but it is possible (and £125 cheaper).
So, all fixed for £25 Thumbs Up
Post #566406 Sun Oct 07 2018 8:45am
x3too
Cheers for the update.
I had a feeling I rushed and bought the wrong one , Is it much faffing about adding the Keyless part? Did you take any pics? I am fairly handy with my hands so will attempt anything - I think its only the motor that goes in the module - Myabe worth swapping the motors across to the old unit - Just thinking aloud Smile
I have found a Pattern part on Ali express thats keyless and a lot cheaper- I used the old part number and it came up .
LR013892
LR013892 SUPERCEDED TO LR091351
Post #566411 Sun Oct 07 2018 11:54am
knwatkins
No problem. It is a little bit of hassle adding it, but not too bad if you take your time. I just sat down and laid everything out in front of me and went through it logically. It took me about 30 mins I would say. It's more of a faff actually getting the part in and out of the door in the first place. Unfortunately, I didn't take any pictures I'm afraid. I just didn't think at the time.
Good spot concerning Aliexpress! For the sake of the extra £10, I'd get it if you can return the part you have already bought.
Post #566434 Sun Oct 07 2018 7:37pm
TubaPlayer
My 2013 has just started doing this today, it's still under warranty (we'll see if it is covered Laughing ) 2016 Black SDV8 Autobiography
2013 Grey Black Edition SDV6 (lasted a while but gone now)
2005 Grey Supercharged Sport (gone but never forgotten)
Post #571615 Sun Dec 23 2018 6:03pm
TubaPlayer
The part no’s above come back as rear door, are the the same for the front? 2016 Black SDV8 Autobiography
Post #571623 Sun Dec 23 2018 9:18pm
mrluke
The aliexpress ones above i also purchased . Haven't fitted yet !
Any recommendations on how to approach it . Seen a few vids that say raising the window etc .
Post #571733 Wed Dec 26 2018 1:27pm
