![]() | Home > In Car Electronics > HDD help on 2010 Model |
Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155 ![]() ![]() ![]() |
I have the same year and spec and my car doesn't have the upload feature on it, I think this occurred on late 2011 and up models when they went to the 8 speed gearbox. The sat nav is loaded in the RRS system and the only way to update is by visiting a JLR garage. There are lots of posts on this side of things as it is expensive and the maps are not up to date. |
The sat nav is a pain but although this won't help you they changed it for 2012 MY so I recently updated mine to the latest (had been running original so was missing a chunk of the M74 for example) via usb stick. 90 quid off ebay. |
215m3 Member Since: 13 Sep 2018 Location: Cambridge Posts: 48 ![]() ![]() ![]() |
Thanks for the replies. At least I know it is not meant to be there rather than a technical fault for not being there. 2010 3.0 TDV6 RRS Overfinch GTS
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 473 ![]() ![]() |
Any chance of a link to the USB Stick you obtained?? |
