Home > General (L494) > 5.0 V8 Engine |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 |
5.0 V8 SC or the older L320 normally aspirated? In a high gear at say 40mph, the SC needs a kick to come alive. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Thu Sep 27 2018 3:33pm |
DangerMouseUK Member Since: 16 Jul 2016 Location: London Posts: 528 |
Would be a newer one from a 2018/2019 car . . . |
Thu Sep 27 2018 4:25pm |
If I understand, you are asking about the actual accelerator effort rather than engine response? Having driven a TDV6 loaner, an SDV6 loaner, and of course my SC, the diesels seem to require slightly less foot pressure.
Thu Sep 27 2018 11:10pm |
Yeah like for more relaxed/restrained driving, the roll on power of the diesels in big 4x4s is very natural.
Thu Sep 27 2018 11:27pm |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
For me, the single biggest difference between diesel and petrol power was/is engine accelerator response.
Fri Sep 28 2018 7:23am |
Need to drive one of the big petrols really and see what they're like!
Fri Sep 28 2018 1:46pm |
Agree with Wilf, once you push the accelerator, the petrol response is instant compared to the 1 second lag of the diesel, even more in dynamic mode. But my perception is the actual pressure required on the accelerator seems to be slightly less on the diesel loaners I have driven. My neighbour has a 4.4, I will see if I can take it round the block Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Fri Sep 28 2018 11:17pm |
rangiejools Member Since: 11 May 2008 Location: Mornington Peninsula Vic Posts: 187 |
What's changed with the 18/19 SDV8 gearbox? RRS P460e 1983 2 door Range Rover ARB Bar X9000 winch ARB Rear Bar now semi retired. Many big trips done in this one. 1982 Rangerover nearly restored. 22 Defender D250 with lots of stuff for outback touring Nice 2013 Freelander TD4 manual (for daughter to learn on) with much better stereo compared with previous SD4 SE with Meridian which sounded bad! 2013 Land Rover Defender ute. |
Sat Sep 29 2018 7:46am |
I can't speak for the Aussie market but for WLTP emissions testing across Europe they've changed the gearbox calibration so now the SDV8 here is the same speed as the SDV6 as you can see from this page;
Sat Sep 29 2018 10:11am |
Non SVR 5.0 SC is quieter than SVR but it still barks and spits when you put your foot down, but it doesn’t give the crackle and pop on the overrun like the SVR. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Sat Sep 29 2018 1:23pm |
Unless you modify the exhaust like I’ve done
Sat Sep 29 2018 2:14pm |
The accelerator pedals are not connected to anything other than a potentiometer, I guess the internal spring rate could be different. MY2016 HSE D SDV6 - gone due to fuel dilution problems. By the age of 50 you have the face you deserve - George Orwell. |
Sat Sep 29 2018 3:15pm |
And I think it probably varies car to car. I used to find the same when I had my M3, mine felt slightly different to BMW’s cars in the same mode. Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Sat Sep 29 2018 11:25pm |
So noise wise its a lot quieter/more relaxed than the SVR ?
Mon Oct 01 2018 4:08pm |
