Home > General (L494) > D.I.Y Running Boards |
Yes you have to cut the plastics,I fitted aftermarket ones.You can either mark where the bracket goes & take the off to cut or do as I did & put the steps up to the plastics & it gives you a good idea where to cut & cut the plastic in situ but watch you don’t cut through the fuel pipes behind the plastics.
Thu Sep 27 2018 4:22am |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 871 |
Thanks for that I think I will cut out in place as well. The rear seems to fall in line with the jack mount , perhaps I am wrong need another look. What did you use to cut ? I have a dremel which I can fit a cutting tool on wonder if that will do ? M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Thu Sep 27 2018 6:46am |
A Dremel should be fine,,i used a old hacksaw blade.
Thu Sep 27 2018 6:49am |
Guys my boards are on and I am well pleased with the quality and fit. I did things slightly different and will describe as this may help others.
Fri Sep 28 2018 8:56am |
Glad you got them sorted,I also took the steel plate off mine by drilling the rivets out & had them painted black to match the car.
Fri Sep 28 2018 8:59am |
