Home > Maintenance & Modifications > Can someone please identify this part please
waynescott523
United Kingdom 2008 Range Rover Sport TDV8 HST Alaska White
Hi and good afternoon to you all, can anyone identify this part from the picture? It's located underneath just in front of the rear wheel on the passenger side.
It's making a terrible vibration noise when raising the suspension, it looks to me like the plastic has been cut out and there appears to be 3 star screws not fully screwed in, and they won't go in any further.
This is yet another issue I'm having with this car, the sooner it leaves my posesion the better. Thanks again for this forum's help I don't know what I would do without all your help. Wayne Updated sat nav
Replacement LED white interior bulbs
Re-badged in Red
New 8" rear headrest screens
PlayStation 2
Current cars 2018 Qashqai tenka + GUNMETAL GREY
2008 RRS 3.6 TDV8 HST Alaska white
Post #565692 Sat Sep 22 2018 3:13pm
The suspension compressor is in the location your describe
Post #565697 Sat Sep 22 2018 3:42pm
waynescott523
Thanks Andy 👍would there be a reason why someone would cut away the plastic cover? Also is that a Different silver case than what should be there as it doesn't appear to screw up all the way.
Thanks for your assistance andy much appreciated Updated sat nav
Re-badged in Red
PlayStation 2
Post #565698 Sat Sep 22 2018 3:53pm
Tyrefitter
Someone might have fitted another pump & couldn’t be bothered to remove plastic cover so just cut it.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #565699 Sat Sep 22 2018 3:59pm
I guess its the more modern AMK compressor
The cover can’t be fitted with these
Post #565700 Sat Sep 22 2018 4:00pm
waynescott523
Do you think there is anything I can do to stop the vibrating from happening? Or maybe what the cause is? Thanks in advance Wayne. Updated sat nav
Re-badged in Red
PlayStation 2
Post #565701 Sat Sep 22 2018 4:10pm
Should there not be some rubber mounting bushes on the compressor somewhere, perhaps these have disintegrated and causing it to vibrate over and above the compressors normal noise.
Post #565710 Sat Sep 22 2018 11:29pm
waynescott523
Cheers col, I'll get someone to look into that this week, it's worth a try.. thank you. Wayne Updated sat nav
Re-badged in Red
PlayStation 2
Post #565711 Sat Sep 22 2018 11:48pm
That illustration is for the Hitachi compressor , if you have the AMK one fitted it should look more like this which is what it looks like you have. The 3 bushes are shown by the 3 mounting screws, I think the part no. for the bush is LR038116 only that number seems to have been superseded to a complete compressor unit which doesn't seem quite right.
Post #565712 Sun Sep 23 2018 12:30am
garrycol
Australia
Looks like they changed the original Hitachi compressor over to an AMK compressor but couldn't be bothered to buy the correct covers so just cut the bottom off the Hitachi cover so it fitted. But the correct AMK covers and install. 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #565714 Sun Sep 23 2018 3:46am
Brit Plumber
The rubbers don’t look too good in the photo but it may just be a bad shot. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #565727 Sun Sep 23 2018 10:28am
waynescott523
Thanks again col, everything you have just said makes total sence now,I was told that they had changed the compressor but had done it on the cheap, and had indeed fitted an incorrect compressor unit as I had to take my car into a reputable range rover mechanic in preston to try and correct the wrongs that had been done. And I had to get everything re callabrated. I really appreciate your assistance col, I now have the information to go back to the car dealer with. Thank you. Updated sat nav
Re-badged in Red
PlayStation 2
Post #565733 Sun Sep 23 2018 12:08pm
Brit Plumber
The compressor isn’t the wrong part. It’s a replacement part that is now recommended but should be done properly. Hacking the cover isn’t done properly in my opinion, but would be more cost. 2019 5.0 SC SVA (Current)
Post #565744 Sun Sep 23 2018 2:23pm
AMK cover is best part of ÂŁ150.00 for two bits of plastic from L/R at there prices, probably get pattern parts a lot cheaper somewhere.
Here you go, looks like they have the bushes as well, same as Sport
https://www.ebay.co.uk/itm/LR-Discovery-4-...SwYFpbPl2p
https://www.ebay.co.uk/itm/Land-Rover-Disc...100623.m-1
Post #565785 Mon Sep 24 2018 6:20am
