Home > Maintenance & Modifications > Gear box additives
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
Gear box additives
2006 Sport. 95,000 miles. Question is.....It would appear the jerkiness (if that's a word) of the engine drive is due to the gear box not operating correctly - before considering a fluid change, is using an oil/fluid additive an acceptable answer? Andrew Kennedy
Post #565524 Thu Sep 20 2018 3:08pm
At that milage, if its never had a fluid change, that is probably to first thing to do.
If that doesn't help, its very easy to add an additive later
Post #565531 Thu Sep 20 2018 4:00pm
andrew kennedy
Thanks for the advice!! Is a fluid change something any garage can do, or is it more of a specialist job? Andrew Kennedy
Post #565539 Thu Sep 20 2018 4:54pm
probably best to find a ZF specialist if you can
Post #565540 Thu Sep 20 2018 5:07pm
