![]() | Home > General > Advice needed on going to view RRS 2012 SDV6 Autobiography! |
JI194 Member Since: 19 Sep 2018 Location: Kent Posts: 1 ![]() ![]() |
Hi all!
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 ![]() ![]() ![]() |
I don’t know the car but she looks well presented. Things to check:
Have you checked the MOT history? It had advisories for front lower arms in 2016 but not picked up on the 17 or 18 MOT so could be worth looking in the Docs for an invoice. Also had a new tyre for the MOT this month. It did 20,500 miles in the 2015 to 16 year and 16,000 miles the year after. New owner maybe?
Forgot to mention warranty - check it, some are useless, then get a good one |
Have to admit I do like the "Monaco" trim but then I am biased |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
The scratching on then driver’s door card metal (or is it plastic...) is evidence of someone wearing a sharp ring... on the driver’s side probably means a chap’s chunky sovereign or knuckleduster rather than a lady’s diamond engagement ring which is normally worn on the left hand in the UK. This is my useless ‘fact’ of the day. Just call me Columbo. |
[Text says 20” LR style 10... no way. Wheels MUST surely be after-market so check they are appropriate including tyres’ speed rating. Wheels are declarable to insurers. Suggest you do not change anything else from factory... honestly, it’s not needed, especially on a white car]
Shiny showroom photos. No images of the important stuff e.g. tyres, condition of brakes etc. FSH is a minimum but it really needs to have the correct wheels and decent tyres fitted before you even consider it. Cheap tyres is a simple walk away. Any history issues, walk away. The service should be done annually or by miles. If it's done 20k miles between "annual" services, walk away.
The reference to the wheels is a direct cut from the spec sheet off something like Topix. 2019 5.0 SC SVA (Current)
