![]() | Home > Faults & Fixes > Red triangle Restricted Performance |
You need DM or another one of the regular mechanics to comment but as a guess I would recommend checking the turbo pipes for splits or loose connections. You can also check the turbo actuator is also moving but it does sound Turbo related. 2019 5.0 SC SVA (Current)
I’ve just done a forum search for that fault code and lots of info pointing towards Turbo inlet low pressure and other faults. Have a look and see if anything sounds similar to your symptoms. 2019 5.0 SC SVA (Current)
laurieandsar Member Since: 19 Sep 2018 Location: Yetminster Posts: 7 ![]() ![]() |
Cheers Brit Plumber, took it back to the garage they found a clip on turbo pipe was broken. they replaced and say all is good.....time will tell. |
