Home > General > 3.6 tdv8 turbo failure....
Brit Plumber
Did the engine runaway? Sounds like (as said above) the seals have failed and sucked the oil out of the engine and through the inter cooler. There’s probably oil in the exhaust too. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #565377 Tue Sep 18 2018 6:40pm
Tm17
Would this cause the engine to be unfixable?
Post #565378 Tue Sep 18 2018 7:13pm
Disco_Mikey
Between min/max is only 1 litre of oil. You need to establish how much oil is left in the sump
More often then not, there is still 5-6 litres left, with the missing amount having been pumped into the exhaust, boost pipes and Intercooler
I have had 3 TDV8’s in the past, that have run very, very poorly, and misfiring badly
All have been cured with 2 new turbos, with no additional mechanical issues Thumbs Up
Post #565379 Tue Sep 18 2018 7:15pm
Tm17
Thanks disco there is hope yet then.
Hopefully it’s just the turbos that need replacing.
What other work may need to be done?
Post #565380 Tue Sep 18 2018 7:19pm
My old TDV8 blew its turbos at about 70k. It's still running, I see, and I sold it last year with 174k on the clock... 2012 SDV6 - it's missing a couple of cylinders
Post #565387 Tue Sep 18 2018 7:46pm
Tm17
What happened when your turbos went. Does it sound similar things to what’s happened to mine?
Loss of power, lots of black smoke, oil leak from front end?
Post #565393 Tue Sep 18 2018 8:00pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
I was fortunate. No smoke, no runaway engine. It simply switched itself off. No engine damage or intercooler damage. "Just" the Censored turbos. Mind you it was no fun with the engine just shutting down at 40mph and trying to coast to somewhere safe with no power stering etc...
2 turbos replaced fixed it and all fine (touching wood. Though was nearly touching cloth when it happened ).
Post #565406 Wed Sep 19 2018 7:23am
When mine blew, I got a loss of performance (no dashboard lights, however) and a good deal of white smoke with a rather unpleasant smell to it. No oil leak that I remember. 2012 SDV6 - it's missing a couple of cylinders
Post #565461 Wed Sep 19 2018 5:00pm
The TDV8 is a pretty robust bit of kit. Provided you didn't dump in enough oil to hydro-lock it (would have been a bang if it had) and provided no bits of turbo have found their way in to the engine, new turbos and a good clean out of the pipework / intercooler etc, should see you right. 2012 SDV6 - it's missing a couple of cylinders
Post #565462 Wed Sep 19 2018 5:02pm
Brit Plumber
It doesn’t sound catastrophic, a mate VW Passat ran away and it only stopped when it ate all the oil. He fitted an Audi Turbo, cleaned out as much oil as possible from the pipes and then ran it for an hour at 2am on the far side of the runway at work and it ran fine for years after that. It did smoke and ran crap for about 15 mins before smoothing out and the oil burnt off.
I think you’ll do fine. 2019 5.0 SC SVA (Current)
Post #565464 Wed Sep 19 2018 5:47pm
Tm17
So I had a phone call from the garage.
Engine seems to be fine from all their checks. 2 new turbos needed and we should be back up and running.
Post #565497 Thu Sep 20 2018 7:10am
