Home > In Car Electronics > Electric seats
mikewill53
United Kingdom 2006 Range Rover Sport TDV6 HSE Baltic Blue
Electric seats
I'm hoping someone can help. The drivers seat electrics dont work on my range rover sport 2006.. I've found what I think is the wiring diagram, I've attached an image. Can someone confirm if this is the actual wiring diagram. Also I've bought a power probe to see if its the actual motor on the seats thats not working. Does anyone know what connectors Id have to connect to on the switch to check.
Thanks
Mike
Post #565180 Fri Sep 14 2018 9:12pm
hoppy_70
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Rimini Red
I can’t answer your question but do know that connectors have been a problem in general on these car seats. Mines a later car but still had to have a repair to the connection under warranty. Worth checking the connector blocks before anything else. Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
Range Rover sport HSE Dynamic P400e Silver
Range Rover Sport 3.0 SDV6 HSE Dynamic 2016 MY
Range Rover sport 3.6tdv8HSE 2007 Gone
Range Rover sport 2.7tdv6SE 2005 Gone
Range Rover sport 2.7tdv6SE 2007 honey
Range rover Vogue 2005 4.4 - GONE and missed
BMW 535d M sport 2006 - GONE not as missed
BMW X5 4.4 2004 sport - GONE
Post #565195 Sat Sep 15 2018 8:58am
wrong diagram.
that is for non memory.
HSE has memory.
CHeck fuse 46 (or whatever number it is ) behind the glovebox
or are you saying only 1 motor don't work?
Post #565199 Sat Sep 15 2018 10:27am
mikewill53
Thanks for the replies... Its the mirrors and drivers seat that doesnt work
Post #565200 Sat Sep 15 2018 10:39am
very much check fuses then.
There is also a small fuse in the red/white wire which should be checked.
otherwise I guess it could be the memory module under the seat
Post #565211 Sat Sep 15 2018 11:20am
mikewill53
Wheres the fuse in the wire located
Thanks
Mike
Post #565217 Sat Sep 15 2018 2:46pm
sorry. Its also behind the glovebox.
fuse 46 and 54
Post #565218 Sat Sep 15 2018 3:01pm
