Home > Technical > EPB
Themoog
EPB
Can someone please explain the EPB on a 2005 RRSS. The right rear hub on ours has developed a squeak once per revolution so I may take it apart to have a look. It may not be the brakes but I want to sort it as its embarrassing... I've noticed also when braking there is a click every spin of the wheel too so something is not right. Just passed an MOT tho.
Is the motor actuator in the centre of the vehicle and pulls on cables as opposed to one being on each wheel hub?
From what I can find on YouTube the actual shoes etc seem very similar to my X5. Will I need a coder to reset anything after (I have a fox well that will do it)?
Post #564694 Fri Sep 07 2018 7:09am
gogsy1956
Best option is to search on here for bodsy's brake Bible. This is a step by step guide to servicing and adjusting the EPB correctly which is vital to the correct operation of the unit. Yes only one central motorised unit that operates the cables and no need to reset anything either if you are just cleaning and adjusting.[/u] 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #564702 Fri Sep 07 2018 12:39pm
gogsy1956
Tech section under definitive list of "how to's" 2010 RRS, TDV8
22" overfinch
Post #564704 Fri Sep 07 2018 12:51pm
Themoog
Ah yes. Just read it thanks.
Post #564720 Fri Sep 07 2018 4:39pm
