Home > General > Squeaky Brakes
Sham91
United Kingdom 2010 Range Rover Sport 3.0 TDV6 Autobiography Bonatti Grey
Squeaky Brakes
Just had new rear brake disc and pads changed on my RRS and even after about 500miles the brakes are still squeaking.
Is this normal?
I took it back to the garage a few days ago and they had a look and said everything seems fine and that they just been bedding in.....
Post #564619 Thu Sep 06 2018 8:00am
Lindab
Absolute rubbish. They are basically saying that every brand new car will have squeaky brakes for over 500 miles as the pads are bedding in Rolling with laughter
Post #564628 Thu Sep 06 2018 11:00am
Sham91
Yeah thats what i thought Yawn
What should my next move be. tbh these guys are absolute Censored
They asked some newbie to check my rear brake discs and pads. He put the car on the ramp and nearly jacked it up too without locking the suspension FFS. Luckily I was there wathcing and had to tell the Censored Censored .
Post #564637 Thu Sep 06 2018 1:46pm
Sham91
I was charged £400 for new rear brake disc, pads......... and front pads......Good price?
£125 in labour ............... Rolling Eyes
Post #564638 Thu Sep 06 2018 1:49pm
Brit Plumber
Assembly of brakes is easy really but they can squeak for many reasons and depends on when they squeal and the type of noise. I bet yours squeal when you press the pedal light to moderately. Are there any signs of copper slip on the pads? Do the calipers look to have new sacrificial shims on the contact points of the carrier?
I suspect they didn’t replace the shims (or what ever they are called) or they didn’t put copper slip on the backs of the pads to dampen the resonance. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #564658 Thu Sep 06 2018 6:03pm
Brit Plumber
I’ve chamfered the leading edge of pads (that don’t already have them) in the past and that also appears to help. 2019 5.0 SC SVA (Current)
Post #564659 Thu Sep 06 2018 6:05pm
Sham91
Thank you mate this has helped alot...all sorted for now lol
Post #564925 Mon Sep 10 2018 1:46pm
