![]() | Home > Technical > Help ! Can’t open bonnet |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5039 ![]() ![]() ![]() |
have you tried the easy test?
Hooversdad Member Since: 05 Sep 2018 Location: Cheshire Posts: 3 ![]() ![]() ![]() |
Thanks for the reply but have tried all of the easy stuff. Can’t get the headlight out because I can’t get the grill off. Have spoken to local LR specialist who said to book it in so they can have a look. Maybe he has some trick of the trade? Really fed up with it, it has only done 40,000 miles and not what I expect from a “ quality vehicle”. It is covered under an extended warranty and they tell me the latch and lever are covered but not the cables so no doubt they will decline to cover unless the garage can be creative with the paperwork! It is booked in with them for its 40k service so hopefully they will be gentle on me. My BMW does not have this bother ! |
Be careful not to press too hard on the bonnet as it is a very thin skin and will dent easily! Widely spaced permanent hand prints are not what you really want on your car 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Just had a look at mine (SC) and the cable runs inside the engine bay over the top of the wheel arch so no way to get to it through the right wheel arch liner.
Another thought, will the handle move at all? If not it’s seized. On my car I could spray WD40 (with the red straw attached) through the grill onto each lock, let it sink in for a while and try again. It may be messy with oil going all over but a clean ups got to be easier an cheaper than breaking bits.
Handle moves freely and returns to rest position when released so I know the cable is not siezed. I am away on holiday at the moment but have conjured up a cunning plan using an old hacksaw blade and some nylon cord to try when I get home next week. If it works I will share the idea on here as it may well help someone else. |
If it moves and returns, that may be a snapped Bowden cable. I’m not sure where the return spring is on the bonnet catch but I’d guess there’s one on the handle. It may be worth taking the handle off and making sure the cable is still attached. 2019 5.0 SC SVA (Current)
Torx drive to remove handle |
