Home > Technical > loss of power and white smoke from exhausts |
Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581 |
White smoke is generally water isn't it? Head gasket, etc.... Get a 2005-2009 RRS (FAH500210) sat nav/dash mat here - the one that wasn't there when you bought the car.
Sat Sep 01 2018 8:46pm |
richtdv8 Member Since: 06 May 2014 Location: Rotherham Posts: 47 |
Possibly, but the coolant did not boil out when I took the expansion tank cap off and there was no white sludge in the oil filler cap.
Sat Sep 01 2018 9:02pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Sounds like turbo... |
Sun Sep 02 2018 5:15am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8974 |
I agree with Disco_Mikey. Same symptoms as when my old TDV8 blew its turbos. 2012 SDV6 - it's missing a couple of cylinders
Sun Sep 02 2018 7:15am |
Ay, more than likely turbo or turbo's.
Sun Sep 02 2018 11:26am |
Downpipes off, and check for oil or seized shaft
Sun Sep 02 2018 2:23pm |
I have just put my flexi camera down the air intakes to the turbo. on the front pipe it came out covered in oil. |
Sun Sep 02 2018 3:59pm |
Ouch |
Sun Sep 02 2018 4:10pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4941 |
There's always a bit or oil near a turbo.
Sun Sep 02 2018 5:46pm |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 865 |
Low miles for a turbo ? Not saying it isn't but these days turbos should go way longer. I have seem turbo land cruisers with 600,000 Kilometers and still going well. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Sun Sep 02 2018 10:12pm |
Fingers crossed for you. Did both the turbos on my SDV6. It was not a cheap job. |
Mon Sep 03 2018 6:44am |
I’ve read on the forum that the TDV8 Turbos can fail early if the engine is turned off while the Turbos are still spinning at fast RPM. Something to do with the distance the Turbos are from the engine and the long oil pipes (Because the engine bay is so tight). 2019 5.0 SC SVA (Current)
Mon Sep 03 2018 6:46am |
I have personally always let any turbo car I have owned spin down first before switch off, and after a hard drive idle for 30 secs or so. That said I mentioned this on a separate thread and it is fair to day others disagreed saying on a modern car not necessary. I prefer my way but each to their own I suppose. |
Mon Sep 03 2018 6:50am |
For the sake of 30 seconds it’s worth it....or take the risk of the bearing burning out, easy choice for me. 2019 5.0 SC SVA (Current)
Mon Sep 03 2018 8:12am |
