![]() | Home > General (L494) > Deployable side step settings. |
All accessory installation and operating instructions can be downloaded from the JLRTopix website in pdf format 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
thomas brown Member Since: 29 Mar 2016 Location: Norwich Posts: 559 ![]() ![]() ![]() |
Hi Tim.
Cornishman Member Since: 12 Jul 2018 Location: Cornwall Posts: 28 ![]() ![]() |
You are correct, booklet part number VPLWPO182, “ To switch DSS on.. Press and hold switch, Press and hold Stop/ Start button, the button will flash 3 times . To turn off repeat the same , and button will flash 2 times “ The steps will not deploy if speed is above 5 kph or train response is set to ...mud/ sand or rock crawl. Hope it works for you.. |
Hi Cornishman.
Eventually I have found this on YouTube
HXM Member Since: 24 Jun 2018 Location: Up North Posts: 81 ![]() ![]() |
I’ve got the dss booklet in the car I’ll take photos tomorrow MY15.5 HSE - SDV6 - Santorini Black |
Hi HXM.
Odd video, my My16 works as I described, press function switch then ignition on and yellow light on function switch will flash. Then turn ignition off , door open or closed. |
Thanks again for all your help |
Terras14 Member Since: 04 Mar 2018 Location: Singapore Posts: 38 ![]() |
I have a most strange encounter with my DSS recently.
