Home > Advanced Factors > DETACHABLE SWAN NECK SECURITY PLATE WITH FIXINGS - WSL
Advanced Factors
Site Sponsor
KIT434 Swan Neck Security Plate Kit
New design – Radiused corners
Manufactured from 304 8mm stainless steel plate, laser cut to shape then chamfer machined on the aperture.
Stops your Tow bar dropping out and trailer/caravan/horse box overtaking you.
Comes supplied with Fittings 2 x M12 x 50 Bolts 2 x M12 nyloc nuts 4 x M12 washers (all zinc plated)
Security aid and an added deterrent to thieves, an expensive item that are normally easily stolen and resold.
Fitting - Chamfer facing upwards to the towbar, drop bolts through from Above the socket, through plate and then washers on and nuts and tighten them up... the plate will bow when tightened but that’s fine, and will not sit flush with the socket face as it’s providing the upwards clamping force.
MPN: KIT434
Brand: Advanced
£24.00 Inc. VAT
£20.00 Ex. VAT
https://www.advancedfactors.co.uk/kit434-s...0032-p.asp
 Paul Redding
+44 (0)23 8052 2776
paul@advancedfactors.co.uk
Post #563792 Thu Aug 23 2018 12:25pm
