Home > Technical > RRS TDV6 2010 ISSUESSSSS
Sham91
United Kingdom 2010 Range Rover Sport 3.0 TDV6 Autobiography Bonatti Grey
Guys some help here please
Just got my Range Rover back after having two turbos replaced and back brake pads, discs.
The steering wheel was vibrating when going over 60-70mph but now it seems fine. Only have some play in the steering wheel, it feels loose :/
Also when I put it into low and selected sport today... it goes from s1 to s6 within seconds and stays stuck in s6? Why is it doing that. Shouldnt it go into auto first when i select S in low instead og going strsaight into manual and jumping to sixth gear.
Only does that while it’s in low height and S is selected. In normal height and selecting S it pulls through the gears fine.
Post #563399 Fri Aug 17 2018 2:56pm
Bladerunner
Why would you select sport mode when in access height?
Post #563409 Fri Aug 17 2018 7:31pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
Odd ?
Post #563417 Sat Aug 18 2018 10:08am
Brit Plumber
I thought he meant low ratio. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #563418 Sat Aug 18 2018 10:44am
Tyrefitter
I thought the same as you BP,,as Bladerunner says why put it into access mode unless your parking up.?
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #563420 Sat Aug 18 2018 10:53am
Coz it lookz well wicked, innit!
Rolling with laughter Rolling with laughter 2012 SDV6 - it's missing a couple of cylinders
Post #563423 Sat Aug 18 2018 1:30pm
Sham91
Low ratio not access height lol
Post #563424 Sat Aug 18 2018 1:38pm
