![]() | Home > Maintenance & Modifications > Weeping brembo.. |
That sounds odd as leeking fluid should come out of the hole in the nipple before it comes from the thread. That is unless the Brembo bleed nipple is different to normal. Is the nipple tight? Is it visibly damaged? 2019 5.0 SC SVA (Current)
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 ![]() ![]() ![]() |
Seems tight and doesn't look damaged. I think it actually may be leaking through the hole as it's popped the dust cap off. Perhaps there is something stopping it seating correctly. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
Brembo recommend tightening to a torque of 19Nm on the bleed nipples, might be worth checking, otherwise could be worn taper/damaged seat on the nipple or caliper, but wouldn't really think it would be the caliper seat.
I’d be tempted to slightly loosen the nipple and retorque. If it still leeks, replace with a new stainless nipple (seen on eBay specific to the RR Brembo) and bleed your brake. 2019 5.0 SC SVA (Current)
