![]() | Home > Maintenance & Modifications > Side steps - confused |
Andyjay123 Member Since: 22 Aug 2014 Location: London Posts: 698 ![]() |
The eBay link states they will fit RRS from 2005 onwards.
I’ve ordered them
Let me know what you think of them as I’m thinking of fitting these to my white sport. 2019 5.0 SC SVA (Current)
I am confused - why would you order them when the listing says they do not fit your car - you even noted this in your original post? If you enter your 2006 4.2 into the compatibility list, it comes up and says does not fit Garry 07MY RRS TDV6 Arctic Frost Aspen Interior |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
They certainly look the same as the one's I fitted to my S/C as well, although they were genuine L/R ones I fitted. There was no mention of them not fitting certain variants, as there is now only one part number listed for all 05-13 RRS1 variants. Cheers Col |
They are for the sport, the seller has described in the title they are for a sport but when the seller has added the compatibility list he put the wrong car. Seen it a lot on eBay. He probably used a template from his Disco listing and forgot to change the compatibility list. 2019 5.0 SC SVA (Current) 2012 5.0 SC AB. Sadly written off by a campervan 23 plate Focus ST (Current) 1942 VEP Ford GPW Jeep (Willys) (Current) 1943 Whites M16 Halftrack (Current) 16 plate Eurofighter Typhoon, 2 x Eurojet engines with 20,000lbs thrust each. 1380mph |
