![]() | Home > General (L494) > Things to check before end of warranty |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Squeaky brakes - seals around rear diff. Can you ask for a health check at your local dealership I think it's FOC. What warranty are you going to use after your current one expires ? 16MY Estoril Blue SVR.............
00by Member Since: 25 May 2018 Location: Northants Posts: 81 ![]() |
Thanks - it's booked in for the first MOT a week before the warranty expires so I'll see if they can do the health check then. I suppose things will get checked at the MOT, as well!
Hi
I have found the approved used well worth it's money over many years - just had a rear diff & dodgy airbag harness sorted - approx £1.5k - Sport before had a rear arc bar close to £2k - the one before that suspension parts was replaced. TOP TIP - LR use a red - Amber - green system - if your health check / mot highlights any Amber issues that are covered under warranty make sure you book it back in for a future health check in a few weeks time - failed components do not fix themselves |
Thanks riverblanche - will check those!
