![]() | Home > General > HST v Autobiography. |
Ones called a HST the others called a Autobiography |
Fairly sure there was never a 4.2SC Autobiography. The HST presumably has the different front and rear bumpers and locking rear diff. 2012 SDV6 - it's missing a couple of cylinders
DEVON Member Since: 14 Apr 2016 Location: Bolton Posts: 264 ![]() ![]() ![]() |
In my opinion the Autobiography was the facelifted HST replacement. 2019 5.0 SC SVA (Current)
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
Yeah..I wasn`t very clear. Just wondered about the spec differences. ![]() |
Silly ![]() |
Ahhh, right ![]() |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5042 ![]() ![]() ![]() |
Would say that's about right, as the Autobiography Sport was only introduced with the facelift version MY10 on. Personally after having both I preferred the look of the HST body kit, although the interior of the facelift is much nicer. Mind you since then have fitted Overfinch GTS bumpers to the A/B. ![]() Cheers Col |
Cheers Col |
HST was an HSE with a body kit and if it was a factory build one on a 2.7 then they fitted the e-diff too and a sunroof IIRC, 4.2 always had the e-diff and there was no Autobiograpghy in 2007/2008. As stated above Autobiography came with the facelift in 2010 and had additional body trims over the HSE. The 4.2V8 was dropped in favour of the 5.0V8, the 3.0 V6 diesel superceeded the 2.7 and the 3.6V8 diesel remained for a few months then it was dropped from the range, possibly because the performance of the 3 litre SD V6 was very close to it but with better fuel consumption and lower emissions, also IIRC DPF became mandatory in 2011. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thanks Tim, that`s great |
Are you thinking about an autobiography Steve ?
No mate...I was asked the question |
Ahh I see !!!
